chunkified Posted July 16, 2008 Share Posted July 16, 2008 (edited) Hey, Sorry about the briefness of this post but I gotta go to work Attached is a hip file with my current dilema. (jump inside the "ground" geometry object). I've fractured a grid and would like to animate each piece "disturbing"/cracking, which will be linked to each piece's proximity to a metaball. (Sorry for the long winded explaination but if you check the metaball's animation you could pretty much imagine what I'd like to happen) Due to each piece not actually falling... I didn't think DOPS was the right way to go... Can anyone shed some light on how I'd achieve this please! Cheers Edited July 16, 2008 by chunkified Quote Link to comment Share on other sites More sharing options...
chunkified Posted July 18, 2008 Author Share Posted July 18, 2008 sorry to bump this thread but i'm twiddling my thumbs here in confusion lol Quote Link to comment Share on other sites More sharing options...
anakin78z Posted July 18, 2008 Share Posted July 18, 2008 Ok, here's something to get you going. I took advantage of the primitives and did all the cracking before the extrude or divide. Basically I color the primitives using the metaball and a magnet sop, then rough up the edges and rotate the prims a bit using that color. It causes the ground to crack as the metaball expands. It's all in the orange network box. Hope this helps. -z room_env.hipFetching info... Quote Link to comment Share on other sites More sharing options...
chunkified Posted July 18, 2008 Author Share Posted July 18, 2008 cheers for the reply! gonna check it out now! Quote Link to comment Share on other sites More sharing options...
chunkified Posted July 20, 2008 Author Share Posted July 20, 2008 thanks for all your help! was just what I needed! tis nice to see your way of roughing the edges also! the random sop in combination with the mountain sop did a similar thing. will post the animation when it's finished Quote Link to comment Share on other sites More sharing options...
