Particle Attribute in SHOP
ssh
How can I make particle attribute affect shaders in SHOP network?
For example, $AGE affecting frequency of noise. The closer age to 1, the less frequency noise has.
I tried using point("obj/model/popnet1", $ID, "Age",0) but didn't get desired result :(
there a number of methods for this, but just to clarify:
are u copying objects onto points ?
ie, then each object inherits the attributes from each point ?
particleShader.hipFetching info...
in this example, i copy an attribute onto each sphere, and then read that into my shader,
its nothing sophisticated, but shows how u can take data from pops/surface into ur shop.
Yes, copying metaballs or spheres, and each object inherits attributes from each point
If I use point SOP and stamping Age or Color attributes all works fine :)
I mean using particle attributes at SOP level works for me.
I try to achieve kinda same thing but at SHOP level.
