ivan Posted August 7, 2008 Share Posted August 7, 2008 (edited) I am trying to compile a 32-bit DSO on a 64-bit machine. I've hacked the hcustom script with the following: else if ( $?AMD64 ) then set SYSTEMDEFS = "-m32 -fPIC" set OSLFLAGS = "-m32" works niceley on a machine at work. Now, I try and compile on my home machine. I had to add a -I/32_bit/usr/include/ to the compile line, and now the linker chokes: /usr/bin/ld: crti.o: No such file: No such file or directory and locate crti.o gives 2 results: /32_bit/usr/lib/crti.o /usr/lib64/crti.o I have tried adding -L /32_bit/usr/lib/ to the compile line, no dice. same error. any ideas? Edited August 7, 2008 by ivan Quote Link to comment Share on other sites More sharing options...
