kiwi123 Posted August 8, 2008 Share Posted August 8, 2008 Hi everyone ! I would like to blur an image and change the blur amount per pixel by applying a grayscale image in the Size of the blur. It seems to be impossible ? I've been told nothing is impossible in Houdini, yet here I'm trying to do something simple Could anyone help out with this please ? I can definitely create a vopcopfilter and do it in there, but my home made blur is much much (did I say MUCH ?) slower than the standard cop one. So if somebody could help me out with a fast blur inside the vopcop I would be very grateful as well Thanks, Wiek Quote Link to comment Share on other sites More sharing options...
malexander Posted August 8, 2008 Share Posted August 8, 2008 Just wire your greyscale image into the Mask input of the Blur COP (on the side) and toggle on the "Per-pixel Blur" parameter. On the Mask page of the Blur parameters, there's a menu which allows you to select which of the input components you wish to use as the mask (it defaults to A - alpha). Quote Link to comment Share on other sites More sharing options...
kiwi123 Posted August 8, 2008 Author Share Posted August 8, 2008 Just wire your greyscale image into the Mask input of the Blur COP (on the side) and toggle on the "Per-pixel Blur" parameter. On the Mask page of the Blur parameters, there's a menu which allows you to select which of the input components you wish to use as the mask (it defaults to A - alpha). That is wonderful ! If only I had tried the per pixel flag would have saved me a whole day of making an efficient blur (although the braintraining was great ) Thank you so much ! Quote Link to comment Share on other sites More sharing options...
