Nerox Posted August 14, 2008 Share Posted August 14, 2008 Guy's, I'm working on a 'exploding' window of a door, due to someone smashes the door. (I'm not sure if this is proper english but you'll get the clew, I hope ;-). Any way I've followed Peter Claes's approach for the procedural breaking part. I'm trying to let the glass break out, by the force which comes from the door movement. I probably could use a force field and animate it, but I think this should give a more realistic result. I've animated the 'door' (in the test it's not really there, only something that should go for the glass) before the dop import node. The issue is the glass doesn't seemed to be effected by the motion add-all, appart from the twisting motion. I've played with the glue options, which only results in the RBD object sliding down along the animated object due to some static force. I hope anyone has any idea's on this one. Its probably very easy since I'm pretty much new to Houdini ;-). I've attached the scene. Fracture_08b.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Nerox Posted August 14, 2008 Author Share Posted August 14, 2008 The glass doesn't seem to respond on any collision objects. I guess I did something very wrong, problem is I just can't get the clew. ;-) Quote Link to comment Share on other sites More sharing options...
mangi Posted August 15, 2008 Share Posted August 15, 2008 (edited) reconfigured your hip file. I cleaned up your file. Not really sure what your problem was , but it is working fine for me. cheers. mangi Fracture_08bfix.hipncFetching info... Edited August 15, 2008 by mangi Quote Link to comment Share on other sites More sharing options...
Nerox Posted August 17, 2008 Author Share Posted August 17, 2008 Mangi, Thanks, indeed it does work for me to. Any way, I found it's pretty hard to do a effect like this (I can hear everyone think: Ow? Really ;-). I think I'll try to do a window falling straigth down, I've found some interesting footage on Youtube. In this video on 1:57 till 2:07 (see link below) a piece of glass is falling down, I tried to get a similar effect. It seems once the glass hits the ground it breaks, the pieces, especially the larger parts slide along the ground, like they hover on it, without jumping up and rotating due to the impact. I tried to get a similar effect, but I can't get anything similar without having the biggerparts jumping/rotating around. What is a decent approach to get suge a effect? Quote Link to comment Share on other sites More sharing options...
Nerox Posted August 19, 2008 Author Share Posted August 19, 2008 Nerox said: Mangi,Thanks, indeed it does work for me to. Any way, I found it's pretty hard to do a effect like this (I can hear everyone think: Ow? Really ;-). I think I'll try to do a window falling straigth down, I've found some interesting footage on Youtube. In this video on 1:57 till 2:07 (see link below) a piece of glass is falling down, I tried to get a similar effect. It seems once the glass hits the ground it breaks, the pieces, especially the larger parts slide along the ground, like they hover on it, without jumping up and rotating due to the impact. I tried to get a similar effect, but I can't get anything similar without having the biggerparts jumping/rotating around. What is a decent approach to get suge a effect? I know this is much of a 'How do I model a car' like question, but there must be some sort of natural sciences explanation for this sort of effect, right? Quote Link to comment Share on other sites More sharing options...
