Procedural instancing
Hi. I want to rotate object inside FOR_ALL_GPOINTS in VRAY from one vector to another:
UT_Vector3 baseDir(1, 0, 0);
UT_Vector3 zDir(0, 0, 1);
UT_Matrix3 NRot;
UT_Matrix4 xform;
FOR_ALL_GPOINTS(gdpa, pointPtr)
xform.identity();
NRot.dihedral(baseDir, zDir);
xform = NRot;
openGeometryObject();
setTransform(xform, 0);
But all geos are disappear.
Thanks.
Hi, Sibarrick!
I thinik, no. I want to rotate geometry in the origin. Any other transformation matrixs as translation or scale will be mult after that. Simply rotation.
Can you post some samples of right transformation?
Ok. The problem is in center of rotation... Geometry are running away with rotation of 0.5 and stay still with 0...
Edited by Nasyrov
  • 5 months later...
