mihai architect Posted August 16, 2008 Share Posted August 16, 2008 Hi people ! I have Houdini 9.5.170 and when I try to scale/rotate/translate an object I pick the axes and I can't see the object as I rotate or move. Only when I let go the mouse. The only thing I see when moving is the handles moving and the object appears after I let go the click. Any way I can fix this? I'm sure it wasn't like this before, but I don't know what messed it up. Help ! Thank you ! Quote Link to comment Share on other sites More sharing options...
graham Posted August 16, 2008 Share Posted August 16, 2008 In the bottom right of Houdini, check to make sure the update mode isn't set to On Mouse Up. Setting it to Auto Update will cause the viewer to update as you transform your objects. Quote Link to comment Share on other sites More sharing options...
mihai architect Posted August 16, 2008 Author Share Posted August 16, 2008 Phew ! That was it ! It works ! Thanks a million for the imediate response ! Quote Link to comment Share on other sites More sharing options...
