KuDDu Posted August 22, 2008 Share Posted August 22, 2008 Hi everybody! I am new in Houdini(previosly Maya user). The target is to render scenes in several local machines. This can be done by: mantra -h hos1, host2 etc. Dut PythonShell after this: >>> import mantra Traceback (most recent call last): File "<console>", line 1, in <module> ImportError: No module named mantra This problem occurs on several machines. I think i need mantra.py file or no? Please help Quote Link to comment Share on other sites More sharing options...
graham Posted August 22, 2008 Share Posted August 22, 2008 The mantra command is not a python command/module. It should be run from a shell that has the Houdini environment initialized. Quote Link to comment Share on other sites More sharing options...
KuDDu Posted August 22, 2008 Author Share Posted August 22, 2008 Hm... but where can i find this "shell". I have only "python shell" and "hscript textport". I understand that this is stupid question but please help me! Quote Link to comment Share on other sites More sharing options...
KuDDu Posted August 22, 2008 Author Share Posted August 22, 2008 (edited) Hm... but where can i find this "shell". I have only "python shell" and "hscript textport". I understand that this is stupid question but please help me! oh! i understand) i am so stupid) shell = comand line or cmd.exe inside) thanks all) STOP: what about THIS code-sample: # # Simple Example Filter # import sys import mantra # Import the mantra module Verbose = False # Process any arguments during initialization of the module for arg in sys.argv[1:]: if arg == '-v': Verbose = True # A callback to change the surface shader of all objects def filterInstance(): if Verbose: print 'Filtering:', mantra.property('object:name') catstr = mantra.property('object:categories')[0] categories = catstr.split(', ') mantra.setproperty('object:surface', 'plastic diff 1 0 0') for c in categories: if c == 'pass1': mantra.setproperty('object:renderable', 0) elif c == 'pass2: mantra.setproperty('object:surface', 'matte') mantra.setproperty('object:overridedetail', 1) Isn't it python-script? I am nativly c/c++ programer but know smth about python PS: even typing in shell "mantra -h localhost, second_host_name" nothing happens. Changing in hserver.ini doesnt help. Rendering by pressing button inside Houdini cases rendering only on local machine(while there is string "mantra -h localhost, second_host_name" Edited August 22, 2008 by KuDDu Quote Link to comment Share on other sites More sharing options...
