Asset announcement: Light Rig Public Beta
Ole
After a good while in developement I am happy to announce my Light Rig Digital Asset.
NOTE: THIS ASSET HAS BEEN CREATED WITH APPRENTICE. DO NOT USE IN COMMERCIAL PROJECTS AS IT IS STILL IN BETA.
Main features:
- Use any geometry as lightsource
- Keyframe all parameters including light source geometry type
- Ability to use geometry with changing point count
- Use an image to color the lights
- Distribute lights according to luminance or alpha values of an image
- Use your own light shader if preferred
- Depth map and raytraced shadows
- Full control over target and light source
- Lots of options to control what you see in the viewport
- Import your texture from the compositor to enable live editing of the light source texture
- Supports animated textures. Enable distribution of lights on an animated texture to get a dynamic setup
- Visual feedback includes, but are not limited to:
-- Light Geometry
-- Light Origin
-- Light Target
-- Relation between source and target
-- Geometry colors relative to the color of the applied texture
-- Display source light attributes directly in viewport (Use the attributes Color, lumi, alpha)
- Plus much more...
Thanks to everyone that tested this thing, and a special thanks to eetu and the kind people in #odforce who helped me out when I got stuck.
If you find it useful or have any comments, do not hesitate to contact me or leave a mark in here!
DOWNLOAD
SHORT DEMO VIDEO (from an older version)
Ole
PS: Also, check out my blog at eidsheim.info/blog :)
Edited by Ole
great rig.
Very easy to use. Might want to make the gap smaller between sections, ie the transform light and target, general options. I had to scroll down for a bit :)
did a quick test with it. Very simple options, rendered super fast as expected.
Awesome tool.
phrenzy84 & Mario Marengo: Thanks for the positive feedback! :)
morpheus101: Thank you for reporting this. A new version of the file has been uploaded which fixes this and some minor naming adjustments. The download link is the same.
