puma.snyder Posted April 2, 2003 Share Posted April 2, 2003 Hi all, been running into problems again. I want use a copy chop to copy an animated channel to trigger signals. The problem is, whenever a trigger occurs, the value of the channel at that time is copied. So it does not account the changes in value after the trigger happens. Maybe this makes it more clear copy chop first input: wave chop (pulses, rest default) copy chop second input: wave chop (ramp, period 1.045, amplitude 10, end 1, rest is default) | math chop (multiply = $T, rest default) You will see what i mean if you look at the channels of the wave, the math and the record chop. Any Ideas what to to? thanks again Quote Link to comment Share on other sites More sharing options...
