"look at" problem
Hi people ! I'm looking for a tube to follow a cube, so I'm using the look at option in the tube parameters. And I set the pivot position to be on the bottom of the tube so it rotates from one end. But when I move the cube the rotation "follow action" happens around the tube center not his pivot I want. Why does this not work the way it should ?
Here is a file:
look_at.hipncFetching info...
