dougb Posted October 28, 2008 Share Posted October 28, 2008 Hi, I'm just starting to convert some of our tools over to Python and I have hit my first wall. I need to be able to evaluate expressions (hscript expressions and/or python) with full support for local variables while looping over a set of points or prims. I found the curPoint() method within the Sop/PopNode() classes however it does not exactly work as expected (like the HDK), or perhaps I am over complicating things. Has anyone created a Sop or Pop with support for expressions (including local vars)? Think point sop or attribute create.... For what its worth I have a bunch of 'utility' nodes that I am porting and I do plan to release them to the general public as soon as they work and I get buy off from the Sony suits. I also have mail in to support but figured I would try the general population too. thanks, Doug Quote Link to comment Share on other sites More sharing options...
graham Posted October 28, 2008 Share Posted October 28, 2008 Hey Doug, I'm pretty sure that Python Sops don't support local variables in parameter evaluation due to the fact that they don't really cook for each point. I'll have to ask tomorrow once the guys in TO get back to confirm. curPoint() is the HOM equivalent of $PT in an expression, but returning a hou.Point object which is kind of not useful. You can get the numerical equivalent by doing hou.curPoint().number(). Local vars can also be gotten using lvar() (lvar('PT'), lvar('VY'), lvar('BLAHX'), though not particularly useful when trying to perform actions in the cooking loop of a python sop. Sorry for the lackluster and short explanation but I'm running out the door. Hopefully I was at least a tiny bit helpful and I'll be able to provide some more in depth info tomorrow. Quote Link to comment Share on other sites More sharing options...
graham Posted October 28, 2008 Share Posted October 28, 2008 So after conferring with the people in the know, there is definitely not a way to do this in Houdini 9.5. The good news is that this is possible to do in the next release of Houdini. Quote Link to comment Share on other sites More sharing options...
graham Posted October 30, 2008 Share Posted October 30, 2008 I believe Doug already knows this, but for anyone else who cares, the ability to do this has been backported to Houdini 9.5 and will be available in tomorrows build, 9.5.274. The function that allows this to work now is the hou.SopNode.setCurPoint() function. This takes a hou.Point as an argument. This can be used as follows to set the point position based on a 't' parameter from within a Python Sop operator. for point in geo.points() hou.pwd().setCurPoint(point) new_pos = hou.pwd().evalParmTuple('t') point.setPosition(new_pos) This iterates through each point and sets the point as being current, so evaluating something like '$PT' in the parameter will correctly resolve to the current point. If you use Python geometry operators, definitely check out the Journal tomorrow as a bunch of useful abilities have been added. Quote Link to comment Share on other sites More sharing options...
rdg Posted October 30, 2008 Share Posted October 30, 2008 If you use Python geometry operators, definitely check out the Journal tomorrow as a bunch of useful abilities have been added. Nice features indeed! Quote Link to comment Share on other sites More sharing options...
