puma.snyder Posted April 8, 2003 Share Posted April 8, 2003 Hi all, Building a chop with 2 inputs in vex builder, how do I get access to the channels of the second input of the created chop? When I use the global vop it seems it just uses the channels from the first input. So what do I have to do?? And is it possible to build a chop in vexbuilder which is timesliceable. If so, what do I have to do? Thanks in advance Achim Quote Link to comment Share on other sites More sharing options...
anakin78z Posted April 8, 2003 Share Posted April 8, 2003 check out the chinput() function. you can specify an input, channel and time sample to grab info from other inputs(or other channels of the same input). Not sure what this is called in VOPs. No idea about timesliceing... sorry Cheers, Jens Quote Link to comment Share on other sites More sharing options...
