keltuzar Posted November 16, 2008 Share Posted November 16, 2008 (edited) I have been playing with houdini's gas solver, and here is one of my first simple test. http://www.serrao3d.com/TestMovs/gasTest1.mov So this is a new sim, and this is what I found what trumps maya's fluid solver. This sim has temp (red stuff) advecting differently with custom vorticle fields from density which isn't moving with a voritcle force. http://www.serrao3d.com/TestMovs/gasTest2.mov Edited November 16, 2008 by keltuzar Quote Link to comment Share on other sites More sharing options...
anakin78z Posted November 17, 2008 Share Posted November 17, 2008 Interesting idea. So the vorticles are sessentially messing up your temperatures, which then gives you an interesting look in your density? That get's me thinking... I'm sure one could set it up so that vorticle strength is controlled by temperature, so that you get the most turbulence in hot areas... or should it occur only in the areas of higher temperature change? I guess there's probably a way to get the gradient of the temperature at each sample... well, maybe anyway. Anyhoo, neat stuff . -z Quote Link to comment Share on other sites More sharing options...
SpencerL Posted November 17, 2008 Share Posted November 17, 2008 Interesting idea. So the vorticles are sessentially messing up your temperatures, which then gives you an interesting look in your density? That get's me thinking... I'm sure one could set it up so that vorticle strength is controlled by temperature, so that you get the most turbulence in hot areas... or should it occur only in the areas of higher temperature change? I guess there's probably a way to get the gradient of the temperature at each sample... well, maybe anyway. Anyhoo, neat stuff . -z I could be wrong since Ive been learning this by trial and error, but the behavior of increasing the Vorticle Confinement parameter on the Smoke Solver seems to increase turbulence in already turbulent areas. But actually I think that deals with the velocity vector field, but Im sure like you said, it could be modified so that it looks at the temperature instead. Quote Link to comment Share on other sites More sharing options...
keltuzar Posted November 18, 2008 Author Share Posted November 18, 2008 (edited) Interesting idea. So the vorticles are sessentially messing up your temperatures, which then gives you an interesting look in your density? That get's me thinking... I'm sure one could set it up so that vorticle strength is controlled by temperature, so that you get the most turbulence in hot areas... or should it occur only in the areas of higher temperature change? I guess there's probably a way to get the gradient of the temperature at each sample... well, maybe anyway. Anyhoo, neat stuff . -z so there are various fields in the smoke object. These fields are either scalar, vector or geometry. In houdini there are predefined data names like Vorticles which is geometry. So basically if u lay down say Gas Vorticle Geometry and turn on points, you can see that it is actually a geometry datatype. To make vorticles work the solver is looking for a "mag" variable... and you can see that in the details view. Also in the node itself in the data name you can see data name vorticles. In the smoke solver, if you dig around you can see that they use a gas vorticle forces node and lo and behold! it is looking for the vorticles data and a vector field to dump the output to. In the smoke solver, the output is going to the general vel which is advecting all the grids that are active. so here is wht I did, I created my custom vector field, called it temperatureVel, created my own tempVorticles data node, and dumped the voritcles output off the gas vorticles forces into temperatureVel. Then all I ended up doing is using gas advect temperature with temperatureVel. You can do interesting stuff like this, where you affect only a certain grid to move the way you want keeping the rest of the grids to advect using the default vel grid... Hopefully the fluid gurus can drop by and give their 2 cents on how the solver is working... again this is me trying to decode what is going in the complex setup they have provided. cheers ps did I mention I heart houdini gas solver? Edited November 18, 2008 by keltuzar Quote Link to comment Share on other sites More sharing options...
keltuzar Posted November 24, 2008 Author Share Posted November 24, 2008 (edited) so here is a new exploration, where I use a low res sim, and used a low res vel to advect the high res sim... Here is a playblast http://www.serrao3d.com/TestMovs/upscale1.mov Here is a side by side of the high to low res http://www.serrao3d.com/TestMovs/upscale2.mov Cheers Edited November 24, 2008 by keltuzar Quote Link to comment Share on other sites More sharing options...
keltuzar Posted December 9, 2008 Author Share Posted December 9, 2008 so I spent a good amount of time trying to understanding what is going on under the hood for the whole flame front/ gas dsd solver.... and I still haven't completely grasped the whole understanding... But anyways here is a quick 100 frames of flame sim using fuel that adds to the flamefront which emits temperature. What I love about the gas dsd is the flame front/surface(fuel) relationship. If someone here can better explain it to me it would be really helpful. http://www.serrao3d.com/TestMovs/simpleFire1.mov Quote Link to comment Share on other sites More sharing options...
melazoma Posted December 9, 2008 Share Posted December 9, 2008 so I spent a good amount of time trying to understanding what is going on under the hood for the whole flame front/ gas dsd solver.... and I still haven't completely grasped the whole understanding...But anyways here is a quick 100 frames of flame sim using fuel that adds to the flamefront which emits temperature. What I love about the gas dsd is the flame front/surface(fuel) relationship. If someone here can better explain it to me it would be really helpful. http://www.serrao3d.com/TestMovs/simpleFire1.mov Check out the 2008 Master Class on Fire. It goes into the gory details of flamefronts and DSD... Quote Link to comment Share on other sites More sharing options...
Aliencorpse Posted December 11, 2012 Share Posted December 11, 2012 I would really like to see these files, I'm trying to get this to work in houdini 12 and I'm haveing a lot of trouble getting the flame fronts to work properly Any help would be great. I want to get this dsd fire working in houdini http://physbam.stanford.edu/~fedkiw/papers/stanford2007-02.pdf 1 Quote Link to comment Share on other sites More sharing options...
