How To press a button through python
Hi, I am stumped on this.
I have an OTL that I created with a button on it. The buttons parameter name is called "doIt".
How would I press this button in python? I saw in Houdini Object Model under hou.Parm the pressButton
option but I am not sure how to pass the parameter that I want to press to this command.
Any ideas?
Ah... Now I have another issue. I am selecting a group of object nodes, and one by one the script is pressing the same button on each node.
Is there a way for me to check the current node to see if it has cooked and the python
script attached to doIt has completed its task?
I have been searching the Hou module and have only found cook. From the looks of it,this seems to just
cook the node. Does it wait for houdini to finish cooking before the script continues?
Ah! that makes sense.
I was reversing where I was putting the call to doIt... :blink:
Thanks!
Walt
Okay, found a way to do this.
I created a hidden parm that my buttonPush script sets.
the hidden parm gets set to 1, I then push the button (doIt) which runs
a secondary script. at the end of the secondary script I set my hidden parm back to 0.
After the buttonPush command I enter an while loop that continually checks the state of the
hidden parm, when the parm gets set back to zero the script continues this allows for me
to cook multiple items and run a secondary script and not have the button push script
Execute automatically.
heh heh... hope that made sense. :lol:
Walt
  • 6 years later...
