Copy and groups need help
Cyvern
Hi there!
I could use some help. Have one box and copy node. Create output groups checked, set as one group per copy. Then one more copy (..like 2d array of boxes), also checked output groups. Problem is that after second copy I cant make one group per box. Maybe some expression in copy gropu field could help? Ty.
Edited by Cyvern
It was nearly it! But I have no template only copy after copy. In moment cant see if it can be someway applied also in my case.
Patrik.
Here's a way to put unconnected geometry into separate groups. Unless you copy onto a template, this is your best option.
grouping_copies.hip
Edited by Allegro
