Miles Posted November 22, 2008 Share Posted November 22, 2008 Hey all! Good morning. I've created this file, it births particles. And puts a trail on them via a split POP. Then i want them to explode like emit in XYZ when it gets over a special limit. Wich in this case is the grid... Hope you can help me flying_things.hipFetching info... Quote Link to comment Share on other sites More sharing options...
aracid Posted November 22, 2008 Share Posted November 22, 2008 hey man I've attached the file that should give u what u want, Im sure there a million ways of doing this, but what i did was add an attribute that gave u the values u wanted to cause the explosion and then used groups to dictate if they should use the attibutes default or desired value, which i parsed to the variation of the split POP. hope this helps flying_things.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Miles Posted November 22, 2008 Author Share Posted November 22, 2008 aracid said: hey manI've attached the file that should give u what u want, Im sure there a million ways of doing this, but what i did was add an attribute that gave u the values u wanted to cause the explosion and then used groups to dictate if they should use the attibutes default or desired value, which i parsed to the variation of the split POP. hope this helps flying_things.hipncFetching info... Seemed so simple! Thanks so much, this will come handy in the future! Much apriciated Quote Link to comment Share on other sites More sharing options...
edward Posted November 22, 2008 Share Posted November 22, 2008 Note that there's also a FireWorks POP. Quote Link to comment Share on other sites More sharing options...
