rob Posted November 23, 2008 Share Posted November 23, 2008 (edited) Recently a user had some questions on using a line and attributes like width , orient etc. Well I had a dig around and created a simple scene using a line with width etc but all is not working correctly.If I attach a simple displacement shader , the line renders correctly but if I pipe the line through a rest SOP and then render , the displacement will not render. I wanted to use the point SOP to add some animated noise. I do not know if this is the correct action from the rest SOP but I have a feeling its something to do with the fact its just a line using attributes and its not classed as a primitive . I would welcome a view on this. Rob rse_tickerTape02.hipFetching info... Edited November 23, 2008 by rob Quote Link to comment Share on other sites More sharing options...
