ranxerox Posted November 25, 2008 Share Posted November 25, 2008 hey all, I'm writing a .clip file importer for imported rbd fracture objects into maya from houdini and I'm a little stumped. In my chopnet I have a dynamics chop, which points to my dopnet and in my field names parameter I am bringing in "p? t? r?". Originally I was bringing in only "t? r?" and setting keys on those objects in maya (via a script) but I realized that the t? vector was only giving me a difference from the initial state, not a world position on rbd_fracture objects. So I export these three vectors now and add the p? to the t? vector to get the world position. This works pretty much for most setups, however if I have an "rbd keyframe active" dop in my dopnet the sum of p and t no longer equals the world position of my rbd object before the rbd is active. I guess this is due to a fundamental misunderstanding of what some of this data means and how I should be exporting it. so, my questions are: 1: is there a way in chops to calculate and export the world space position of ebds (even ones with the keyframe active dop on them) 2: could someone give a rundown of these different variables and what they mean, I found the documentation a little lacking (or perhaps I didn't know where to look). I've attached a scene which shows my problem. the "extract transforms_rbd_fractuire" subnet contains my current export setup and the "rbd_transfer_test_fbx" is the result in maya imported via fbx. you will notice there is another little problem where the maya objects are a little ahead in time from the houdini objects. I suspect I am doing something wrong with the frame rate somewhere. thanks for any insight anybody can provide. -ranxx rbd_transfer_Test15.hip Quote Link to comment Share on other sites More sharing options...
