huisho Posted November 28, 2008 Share Posted November 28, 2008 I downloaded latest Houdini for 32-bit linux to run in apprentice mode, but have the following problem: /opt/hfs9.5.241$ houdini /opt/hfs9.5.241$ Warning: OpenGL shader extensions not available. This is a limitation of your video card or driver, and will prevent Houdini from using GLSL shaders. Set the HOUDINI_OGL_ENABLE_SHADERS environment variable to zero to avoid attempts to use this extension. ERROR: could not obtain GLX visual! Most likely cause is a lack of 3D acceleration. Check your configuration. so splashscreen arrives and then disappears. I tried with HOUDINI_OGL_ENABLE_SHADERS=0, but got rid of warning only. There is not very good graphics in my machine (Intel Corporation 82915G Integrated Graphics Controller) , but it has direct rendering: $ glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.2 <<skipped>> 3 GLX Visuals visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x6b 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None I tried both with compiz turned off and on, the result is the same. Another funny thing: I tried to run Houdini (9.5) from remote machine (via ssh -Y) and it runs! But swears hard about DRM absence and lots of BadMatch X11 errors. Any ideas? Quote Link to comment Share on other sites More sharing options...
khasperha Posted November 28, 2008 Share Posted November 28, 2008 Hello Can you execute xsreensaver? or any other 3D app? If not --> Reinstall your graphic driver and configure your xorg.conf (if it's not done automatically) :coffee1: ... Quote Link to comment Share on other sites More sharing options...
