how to get Gloss spec in the Illuminance loop?
kensonuken
Ive been trying to make some custom shaders which is similar to peterBowmar`s rendering separate lights with different passes so I would like to know how do I add gloss parameter in the PJB BRDF functions?
I know the equation what makes the gloss spec but how do I design a node which can make the illum loop to work with it..
any suggestions please help me...
ohh its the place I need to integrate the code...
now I got it... thanks alot Alan..
I want to make sss with all these diffuse and specs to output per lights.. so i need to find sss code... I found 3delight`s sss which is really good enough for my application is there anything like that in Mantra? which is as good enough as 3delight?
I just need to do these things and I am almost done for my current requirement.....
Edited by kensonuken
