problems with glue_object
e=mc^2
hello,
I have a problem with a simple simulation of a chair which is being breakdown.
Some parts of the chair after impact behave as a single object and
should strongly as a few (are connected with each other but physically
apart).
And the second problem with rbd autofreeze, if it is
connected to the chairs it falls apart after a while.
first problem you can see with "chair_alone" node enabled and second problem with "back" and "seat" nodes enabled
sorry for my english ;)
simple_explosion
haven't houdini in front of me so can't take a look at your file... Are you sure that your chair's parts behaving like a single object aren't part of the same group ?? if it is , you should delete all your groups, add a connectivity sop, then a partition sop and use as a rule $CLASS .........
hey
MMM, it looks like ur scene was in a good place,
the glue threshold is a bit high,
i dropped it way down just to get rid of any pieces that stuck together even after the point of collision.
i also reverted back to chair_2, because that had more distinct groups as apposed to chair_1, because that only had a couple of groups.
have a look at the file :)
chair.hipnc
:blink:
