asset question
mic
hello!
i am creating some asset in object-level (cameras, geo, etc). there is some ordered menu and i want to toggle display of some objects (inside the asset of course) changing items of this menu. How can i do it?
for example, before asset i created null object, oredered menu in it, and wrote few strokes, smth like:
if (`ch("obj/null1/mode")` == 0) then
	opset -d off obj/my_node;
etc.
and add it to callback script in this oredered menu created in the null object. Hscript uses the full paths. And if i want to do the same in asset my paths must be relative.. So i don't know right now how to solve this..
Edited by mic
and one more very strange problem....
doc
Menu script field
Enter a script here whose output is a space-separated list in the form:
token "label" token "label" ...
For example:
all "All objects" sops "Surfaces" dops "Dynamics objects"
ordered menu is done, but this menu script doesn't work! what can it be?..
(the first problem probably solved : callback script smth like
opset -d toggle `oppwf()`/geo1 `oppwf()`/geo2
about stupid problem 2 - can anyone post an example - only one node with simple ordered menu created parameter - and menu script
all "All objects" sops "Surfaces" dops "Dynamics objects" ?
is this only my bug, or i've done somewhere very stupid mistake..
Edited by mic
and this problem also solved.) i forgot 'echo' before)
thank to all, maybe this funny questions and answers will help someone)
the battle continues)
i didn't notice last time -
for example, create ordered menu 'qqq' and menu script:
set res = " lalala \"tratata\""
echo $res
and in textport
/ -> opparm -d /obj/geo1/sphere1 qqq
opparm /obj/geo1/sphere1 qqq ( 0 )
why so? how to set 'lalala' or anything except index of token?..
