rakkaka Posted December 17, 2008 Share Posted December 17, 2008 i try to achieve this effect with just a part of an image you can find it here: "Blowing an image away using particles" on http://www.sidefx.com/index.php?option=com...&Itemid=132 i use a pre-multiplied image (with alpha channel).... but i don't find a way to select or use just this area for getting particles with the ride size. when i select just the range of the alpha i can not use $BBX/$BBZ... maybe someone has an idea or a hint where to look?!?!?! is there a way to do it with some VOP nodes...???? thanks Quote Link to comment Share on other sites More sharing options...
jacys Posted April 29, 2009 Share Posted April 29, 2009 rakkaka said: i try to achieve this effect with just a part of an imageyou can find it here: "Blowing an image away using particles" on http://www.sidefx.com/index.php?option=com...&Itemid=132 i use a pre-multiplied image (with alpha channel).... but i don't find a way to select or use just this area for getting particles with the ride size. when i select just the range of the alpha i can not use $BBX/$BBZ... maybe someone has an idea or a hint where to look?!?!?! is there a way to do it with some VOP nodes...???? thanks kill when color equal black? Quote Link to comment Share on other sites More sharing options...
