borisb2 Posted December 17, 2008 Share Posted December 17, 2008 Hi, .. not sure if that will work out. I have a setup where a colored-curve "masks in" specific primiteves of a cracked ground via attribute-transfer. The goal is that all affected pieces start to fall down. The problem is that the dop-network somehow cannot handle the generated object-group at runtime and fails. I attached a testscene. As soon as I activate the delete-group (for masking in the pieces) in SOP, the DOP-network fails. Is there a way of getting this to work or do I have to go the way over particles/instancing ? Or in general: how do I group only specific objects to be affected by gravity? Thanks crack_collapsing_test.hip Quote Link to comment Share on other sites More sharing options...
borisb2 Posted December 19, 2008 Author Share Posted December 19, 2008 I made some progress the last days -> I copy a color-attribute from an animated curve and project it (through the distance-threshold) to the nearest pieces on the ground-object. That way I animate what pieces should fall down. I group them together based on their red-color and feed that group to a fractured RBD-object. All chunks that don crack_collapsing_test.hip Quote Link to comment Share on other sites More sharing options...
