JDenker Posted December 19, 2008 Share Posted December 19, 2008 hey fellows, maybe one of you can solve or help me with this particular problem regarding installing linux i have a P4 QuadCore Q9550, Asus P4Q Pro Mainboard and a nVidia GF GTX 280. i downloaded ubuntu linux 8.04 and burned it as a image on cd. installation worked just fine for me. After installing while booting into linux, linux fails to load the interface. im getting a BIOS BUG #0[49435000]. i guess its because my kernel is being not configured to load the necassary module to boot from a non - AHCI SATA conncection. But im not sure. I tried adding all_generic_ide noapic and acpi=off in the kernel command line but nothing helped so far. the booting stopps at [59.306204] /build/buildd/linux-2.6.24/drivers/hid/usbhid/hid-core.c: v2.6: USB HID core driver maybe you guys discovered similar problems and could help me here. thanks a lot for your time! -Jens Quote Link to comment Share on other sites More sharing options...
wolf_cub_one Posted December 19, 2008 Share Posted December 19, 2008 It's sounds like you've already tried this but just in case: http://www.linuxquestions.org/questions/su...hout-it-639416/ If nothing else works, I would just download Ubuntu 8.10 and try that instead. Quote Link to comment Share on other sites More sharing options...
JDenker Posted December 21, 2008 Author Share Posted December 21, 2008 Okay thanks wolf for your reply, i solved it tho.. as i thought, the problem causer was, that AHCI was turned on in bios. ty! Quote Link to comment Share on other sites More sharing options...
