referencing channel using switch routing
peppino3d
Hello,
I've got a little question about the correct syntax for referencing a channel:
I've got two identical nodes plugged into a switch and the switch plugged in the third node.
Depending on the switch status (0,1) I would like to have the third node channel referencing either the first or the second node (with suffix 0 or 1):
graph
null_0 null_1
switch1 (0,1)
null3
current null3 expression:
ch("../null_0/myvalue")
theoretical new null3 expression:
ch("../null_"`ch("../switch1/value")`"/myvalue")
Any help on the correct syntax? :)
thanks
Peppino
Cannot test either (back home on holiday) but will try as soon as I'm back to the office
Thanks it makes sense! :)
P
Cannot test currently, but I guess it's:
ch("../null_" + ch("../switch1/value") + "/myvalue")
Backticks is for evaluation expressions in string parameter fields.
