saml Posted January 5, 2009 Share Posted January 5, 2009 Hi, I am developing a python script and have come across an issue with the hou.hda.installFile() module and I am wondering if anyone can shed some light on how I can resolve it. The following are two scenarios, one which works and the second which calls an exception and fails unfortunately I need the second one to work ==Scenario 1== The following was executed in the python shell within houdini and works with no issues: >>> path = "C:/Documents and Settings/Administrator/My Documents/RSL/rel/watermelon.otl">>> hou.hda.installFile(path) ==Scenario 2== This is a snippet of the code I have used in my python module which I have imported into and run in houdini: path = re.sub(r'\\', r'/', "\"" + self.shaderDir + '\\' + stringSelection.rstrip('slo') + 'otl' + "\"")print path hou.hda.installFile(path) The path output in the console from the print command appears exactly the same as the first scenario "C:/Documents and Settings/Administrator/My Documents/RSL/rel/watermelon.otl" however, fails with the following exception appearing in the houdini console: Traceback (most recent call last): File "C:/DOCUME~1/ADMINI~1/MYDOCU~1/houdini9.5/scripts/python\hrsl.py", line 136, in OnImport hou.hda.installFile(path) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.169/houdini/scripts/python\hou.py", line 11004, in installFile return _hou.hda_installFile(*args) TypeError: in method 'hda_installFile', argument 2 of type 'char const *' When I substitute the "path = re.sub..." attribute with a direct path to the otl it works successfully even though the string appears exactly the same in the print statement of the path. It seems there is an issue with the type of attribute being generated but I am unaware of the best approach to solve this. Any help would be much appreciated!! Sam. Quote Link to comment Share on other sites More sharing options...
symek Posted January 5, 2009 Share Posted January 5, 2009 (edited) Hi,I am developing a python script and have come across an issue with the hou.hda.installFile() module and I am wondering if anyone can shed some light on how I can resolve it. The following are two scenarios, one which works and the second which calls an exception and fails unfortunately I need the second one to work (...) Any help would be much appreciated!! Sam. Did you try your path with os.path.isfile() call? It will check if system can see your file despite of Houdini. Another thing you might consider is using os.path.join() which will create a *correct system path from various chunks like: "c:\", "Documents and Settings//user", "houdini9.5/otls", "myfile.otl". Very convieniet. The problem seems to be that your string created by regular expression consists with extra " " quotes around so path starts with "..., which is not a correct path for Python I think. Edited January 5, 2009 by SYmek Quote Link to comment Share on other sites More sharing options...
saml Posted January 5, 2009 Author Share Posted January 5, 2009 Thanks for the speedy reply SYmek! I hadn't thought to use those os module commands too, they are very useful. When testing isfile against the path it returned a false boolean. I got rid of the extra quotes and isfile now returns a True result, but the same initial error arises, so there must still be an underlying problem with the path string... Code: path = os.path.join(self.shaderDir, stringSelection.rstrip('slo') + "otl")path = re.sub(r'\\', r'/', path) print "Path: " + path print os.path.isfile(path) ##TEST## explicitPath = "C:/Documents and Settings/Administrator/My Documents/RSL/rel/watermelon.otl" print "Path: " + explicitPath print os.path.isfile(explicitPath) Output: Path: C:/Documents and Settings/Administrator/My Documents/RSL/rel/watermelon.otlTrue Path: C:/Documents and Settings/Administrator/My Documents/RSL/rel/watermelon.otl True As a test I tried to force the path to be a string using: path = "".join("%s" % path) This still resulted in the same initial error. Maybe there is some kind of other string conversion I need to do? Thanks again for your direction. Quote Link to comment Share on other sites More sharing options...
saml Posted January 6, 2009 Author Share Posted January 6, 2009 Thanks again for the assistance! I have now resolved the problem. Although the strings both appeared to be identical yet only the explicitly defined string worked with the hou.hda.installFile() method, using the type() function on the path variable I discovered it was of <type 'unicode'>. I converted the path variable to a string using the path = str(path) command and now it executes successfully! Cheers, Sam. Quote Link to comment Share on other sites More sharing options...
