about "du,dv" in houdini!
zbhoudini
there are parameters "du,dv" to represent an estimate of the amount that the surface parameter u ,v change from sample to sample.for example:
#define MINFILTERWIDTH  1e-7
#define MINDERIV        0.0003    /* sqrt(MINFILTERWIDTH) */
#define filterwidth(x) (max(abs(Du(x) * (du)) + (Dv(x) * (dv)),MINFILTERWIDTH))
;are there some parameters like that to substitute for "du,dv" in houdini?
check out the "primduv" expression
Have a look at this wiki page. Following the mappings in that table, your RSL fragment would become:
#define filterwidth(x) (max(abs(Du(x)) + abs(Dv(x)),MINFILTERWIDTH))
BTW, note that I added another abs() to your expression as it wouldn't make much sense otherwise... perhaps a typo when copy-pasting?
Cheers.
