Question for "shader writing in Image3d tutorial"
puma.snyder
Hi
what do I have to set in the image3d output driver parameters tab in order to get this shader from the "shader writing in Image3d - part 2" tutorial to work properly? Do I have to set any "render as" although I already specified geometry in the shader? When leaving at the defaults the rendered volume does not match the geometry. Here is the shader.
Any Ideas?
image3d voxellize_backhit( string geofile = ""; vector test_vec = {0,1,0} )
float pu, pv;
int prim_number;
vector curP = P;
vector nml=0;
density=0;
prim_number=intersect( geofile, curP, test_vec*1000, curP, pu, pv );
if( prim_number > -1 )
nml = normalize(prim_normal(geofile,prim_number,pu,pv));
if( dot( normalize(test_vec), nml ) >= 0.0 )
density = 1;
Thanks in advance
