Symbolic Posted January 19, 2009 Share Posted January 19, 2009 Hi, I am trying to read a value from a parameter on an HDA. It should be somethin like. self = hou.pwd() number = self.node.parm("nodecount") but it just does not work. I really find the Python help section in Houdini a bit confusing. Like: I know that I can list a value from a parameter of a node with: opparm -d "node" "parameter" In the help it says that: Replaced by: hou.Node, hou.ParmTuple, hou.Parm When I go in any of these sections I see lots of confusing things like: hou.Parm class The parm() function returns a parameter by its path. The Parm class represents a parameter on a node. asCode(self, brief=False, function_name=None) → str ... deleteAllKeyframes(self) ... evalAsFloat(self) → float and others... none of these make any sense and explain how to actually query a parameter field on a node or an HDA? What does that mean? Quote Link to comment Share on other sites More sharing options...
aracid Posted January 19, 2009 Share Posted January 19, 2009 hey man is this what u looking for ? hou.node('/obj/geo1').parm('tx').eval() more info can be found http://localhost:48627/hom/intro Quote Link to comment Share on other sites More sharing options...
Symbolic Posted January 19, 2009 Author Share Posted January 19, 2009 hey manis this what u looking for ? hou.node('/obj/geo1').parm('tx').eval() more info can be found http://localhost:48627/hom/intro Yeah! Cool! I used it as this: self = hou.pwd() number = self.parm('nodecount').eval() hou.ui.displayMessage(str(number)) "nodecount" is just a parameter at the HDA level. So it works. And that link has actual examples of the usage. Thanks. But what is all the stuff that comes when you go inside the help for hou.Parm Quote Link to comment Share on other sites More sharing options...
