Reflection map orientation
Hi,
I know it's a very basic question, but I just don't find an answer to it in the documentation. In every reflective material's properties there is an Env Map Space menu which has an "Use /obj/null1 (or other object)" option. My question is how can I define that which object's transform is used in the lookup process?
Thanks
Mate
  ihab said:
create a null at the obj level. You'll find a check box in one of it's paramaters that says (export transform or something like that) sorry i don't have houdini on this computer.
in the render tab of null objects there is a check box which writes: "Output transform as render space (RIB/IFD)" which sounds really promising, but even after setting this my reflection map doesn't react to rotating this null node.
thanks
Mate
