pbowmar Posted February 28, 2009 Share Posted February 28, 2009 Hi, I need to write a VEX Shadeop that is pretty simple, it needs to check to see if the current geometry being shaded is in a primitive group and return 0 or 1. The Primitive group list to check against will be in a text file specified as an argument to the VEX function. Mario's awesome data caching example will allow this to be as efficient as possible by loading and storing the text file once. I can do most of it but I haven't use the HDK in over a year (tip: Don't become a manager if you want to retain your Houdini/HDK knowledge!) and my little brain isn't coughing up an idea on how to access the geometry being shaded from the shadeop to look for the group. Any ideas? Pseudo code, a class to look in etc gratefully welcomed. Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
mrice Posted March 4, 2009 Share Posted March 4, 2009 Were you able to figure this out? If so I'd love to know how its done... I cant seem to get HDK VEX functions working at all, including the example with the drand48() and time() functions. Quote Link to comment Share on other sites More sharing options...
pbowmar Posted March 6, 2009 Author Share Posted March 6, 2009 Were you able to figure this out?If so I'd love to know how its done... I cant seem to get HDK VEX functions working at all, including the example with the drand48() and time() functions. Nope, though I did get Mario's caching example from another thread working OK. The trick with HDK VEX functions is the VEXdso index file to find the .dso file. You can test it easily by doing: vcc -X surface which will print all custom VEX functions at the bottom of the list. If you compile and install then do the above but don't see it, then it just wasn't found, likely due to the VEXdso file not being correctly configured. Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted March 11, 2009 Share Posted March 11, 2009 Hi Peter, It's been awhile since I wrote any VEX ops, but it wasn't all that difficult, maybe things have changed(?). Have you been able to write this yet? I can help out if you need another set of HDK eyeballs to look at the problem. :-) Mark Quote Link to comment Share on other sites More sharing options...
