How to add custom RenderMan renderer?
Hi all,
I'm trying to add a RenderMan-based renderer to Houdini (9.1), though a newbie if truth-be-known.
I've taken an existing RIB*.py and RIB*.ds, modifying them accordingly, but nothing new is displaying within the RenderMan Render Target dialog/pull-down... have I missed a file somewhere or these entries hard-coded within Houdini?
Any help at this point would be greatly appreciated as I'm starting to lose my sanity. :(
  renderguy said:
Hi all,
Welcome!
Aqsis for Houdini, great to see that!
You need to create your own ROP driver (which might be customization of existing PRman ROP), it will have soho_program parameter, that should point to your python soho module. You can check how this works in some of current drivers (most of them are assets).
Check also Jason's educational journey about soho module:
http://forums.odforce.net/index.php?showto...5&hl=indigo
very informative.
Good luck!
skk.
  renderguy said:
Hi all,
The easiest way would be to edit the existing RIB output driver and
make minimal changes:
1) Copy $HFS/houdini/soho/RIBprman14.0.py to ~/houdini9.5/soho/RIBaqsis.py
Perhaps choose a different set of properties closer to what Aqsis has to support.
Make sure to edit the Features() at the bottom of the file.
2) To test this out, put the following line in the RIBaqsis.py file,
right near the top (after the "import RIBsettings" line for example)
print "# Loading Aqsis settings"
3) Now, put down a standard RIB output driver.
Run the command "opparm /out/rib1 target aqsis" from an hscript
textport.
The menu in the GUI will still show prman14.0 because the GUI
hasn't been modified yet.
4) Generate a RIB file. You should see that the print that you put
in your settings has made it into the RIB stream.
This all works because in RIBsettings.py:load(), you'll see that
the "target" parameter is evaluated as a string, and then, that
version of RIB settings is loaded.
From here:
1) Customize an output driver with the correct UI
2) Add a dialog script to specify what "Rendering Properties" show up
when the user edits rendering properties.
3) If needed, copy the python scripts to customize the RIB generation
4) Create something like slo2otl.py (see the source in $HFS/bin) to
etc.
But at least, you have a starting point.
