Nubnubs Posted March 6, 2009 Share Posted March 6, 2009 Hi guys, I've attached a file of something that i'm tring to get right but don't know houdini quite well enough to wrap my head around my problem. Basically what I need to do is take the curves that are in the scene and resample the points leaving equal spacing between the points independent of the scale of the curve which stagger up and outwards from the bottom to teh top. Is there any way to do this? I hope that I have explained this sufficiently. CurveBuild.hipFetching info... Quote Link to comment Share on other sites More sharing options...
stevenong Posted March 6, 2009 Share Posted March 6, 2009 You can use a Resample SOP and set the Length parameter to what you need. Cheers! steven Quote Link to comment Share on other sites More sharing options...
