MENOZ Posted March 10, 2009 Share Posted March 10, 2009 Hello! I noticed that polywireSop continues to allocate memory until houdini crashes, giving the memory allocation error. Try to create a poly object, append a polywireSop, now in the task manager take a look at houdini's memory. play with the polywireSop, change the radius, check and uncheck something.. the memory grows. If i go in the cache manager and clear the cache it seems to remain unaffected. I tried to use the Unload flag on the node but nothing happens. I'm on winXP, 2GB ram, lot of free space on hard disks. I noticed this happen navigating in the houdini's help pages, the memory continue to grow, but never unloaded, even if I close the help pane. anybody knows if this is a bug? Should I configure something about memory allocation in houdini? some gobal varialbes to set? thank you Quote Link to comment Share on other sites More sharing options...
aracid Posted March 10, 2009 Share Posted March 10, 2009 hey man I haven't experienced that exact bug, but try submitting a bug/RFE on sidefx.com or try making sure u have the latest build available. I hate it when scenes just leak memory and something like that happens :/ Quote Link to comment Share on other sites More sharing options...
