flipping cubes
cspears2002
As you may know from my earlier post, I took a poly mesh box and broke it into separate cubes. I colored the faces facing the camera red and the faces looking to the camera's left blue. Moving from right to left, I want to rotate the colored cubes -90 in Y. Basically, rotate the first column of cubes with red faces -90 degrees in Y. Then rotate the second column and so on until the last column of cubes with blue faces are rotated. I want the cubes to spin about their axis. I'm not sure how to go about accomplishing this. Any hints?
chris_building_v05.hipnc
