itriix Posted March 23, 2009 Share Posted March 23, 2009 (edited) hi everyone, i'm having an issue trying to render out a comp: i've run into a weird problem i'm encountering where, i've built a comp in my cops, , a still frame as the background and a particle effect on top *which is multiple frames*, when i connect it to a rop output node, only ends up rendering the particle effect and doesn't seem to show the bottom layer. any ideas? thanks much Edited March 23, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
aracid Posted March 23, 2009 Share Posted March 23, 2009 mmm that sounds wierd so when u look at ur last node, before the rop that writes out the files to disk, does the image look right? view the alpha, cause u might need to set your backgrounds alpha to 1, because what ever u viewing the images with might be pre-multiplying the particles alpha, and not including ur background's alpha. so i would start with that. Quote Link to comment Share on other sites More sharing options...
