bareja Posted March 24, 2009 Share Posted March 24, 2009 Hi, I'm wondering how works DOP Import option in POP Network operator, there is no example in help... anyone knows ? cheers pop_dop_import.hip Quote Link to comment Share on other sites More sharing options...
stevenong Posted March 24, 2009 Share Posted March 24, 2009 You can only import particles into DOPs but not the other way around. However, DOPs will modify the popnet and vice versa. I've attached a simple example and I used the shelf tools to get the setup going. Steps: Go to the Create Particles shelf tab & click on Emitter Next, click on POP Object tool in the same shelf tab & select the particles in the viewport. An AutoDopnetwork is created I added a RBD Object myself and moved it above the particles Re-arranged the DOPnet slightly Added a Split POP to the popnet Done Hope this helps! Cheers! steven PS I moved the post over to the DOPs forum pop_dops.zip Quote Link to comment Share on other sites More sharing options...
linhan4444 Posted April 10, 2009 Share Posted April 10, 2009 thank you steven Quote Link to comment Share on other sites More sharing options...
