where is pyro shader
feeling
it's on the material palette, at the bottom with various incarnations
Sorry, but there may be some confusion there. The materials that are at the bottom of the palette are the same as the materials that were in H9.5 (possibly with some adjustments here and there). The new Pyro "Shader" is coded using VEX and so was left as a VEX shader and not converted into a material. This is something that may change at some point, but for now, you can place it into your network either by using the shelf to create your pyro effects, or by pressing tab in SHOPs and selecting "VEX Pyro"
