displacement vs bump in houdini
Hi everyone, hope you will help me to understand this issue.
in fact what i was searching for is bump mapping in houdini , so after some searching and tests, i got confused ...
because i created a burlap material directly from the material palette and inside it i just replaced the displacement vex node with a bump map node
the render result still looked like a displacement though :S (the edges of the geometry didn't keep unchanged), then i entered inside that bumo map node
and i found there is a displacement node inside :S:S.
can anyone please explain to me displacement vs bump in houdini ? and clarify things about what i did?
Best Regards
Best Regards
Hi! I answered in your topic on SESI forums: http://www.sidefx.com/index.php?option=com...p;p=73667#73667
