Randomizing Shader Parameters with Instance node
here is a very fast example
look at the material tab of the sphere object
trere is material parameter override used on base color of the clay material
and it uses pointinstance expression to get the random color for each point
you can use this expression directly on material parameters, but I chose the override way here
material_instance_example.hipnc
Thanks,
I was trying to use instancepoint in SOP level Which was wrong !
Thanks,
according to instancepoint() help:
"You can not use this function at the surface level, because instancing only works at the object level."
this is kind of logical, because SOPs change geometry and instancing is based on the idea that there is only one geometry held in memory and is used for every instance with some variations(transforms, materials) applied on top. So any sop change based on instancepoint would necessairly create a geometry copy in memory which will ruin the whole effectivity of instancing and will be the same as copystamping technique.
