Symbolic Posted May 5, 2009 Share Posted May 5, 2009 Hi, I have been experimenting with python in Houdini for a while. Well the python sytax itself is very well documented. But I really do not understand what is going on in the Houdini help. Like I managed to build my first python codes looking at other examples. Things like: hou.node('../DATA').parm('list').set(" ".join(connected)) which will store the value of an array called "connected" as a string named "list" on a node called "DATA". Well, I can understand that. But when I try to look for each individual element that builds that single line of code. There is nothing?! There is somethin called "hou.Node class". Under this there is lots of things that I just do not understand. Like: childTypeCategory(self) → NodeTypeCategory what does this arrow mean? what is "NodeTypeCategory"? inputs(self) → tuple of hou.Node what? It is actually used as: hou.pwd().inputs()[0].name() this sometimes works as: hou.pwd().inputs() Why? I can see that [0] means the first element of the array of the list of the inputs. But where is that piece of information in the help? Something I have learned from examples and by asking people. There is no explanation about this anywhere... or I am not able to find it? Any ideas? What is the way of understanding the HOM help? Quote Link to comment Share on other sites More sharing options...
anim Posted May 5, 2009 Share Posted May 5, 2009 it is a little based on your knowledge of houdini and python the little arrow is nothing it just separates the command from the type of the result example in hou.Node help you can see name(self) → str this means that if you have a variable A which type/class is hou.Node then the command A.name() will give you string type so if you call B= A.name() then B will be string variable and will contain the name of the A node as you can see in help knowing all this, you can read following (still in hou.Node help page) inputs(self) → tuple of hou.Node as: A.inputs() will give me tuple of all the inputs of the node A and it will be of type hou.Node so C = A.inputs() will give me this tuple (tuple in python is something like read only list type or array if you come from other languages) then C[0] is the first element of the tuple and its type/class is as you allready know hou.Node so you can call C[0].name() and you will get the name of the node which is connected to the first input of the A node you can get the same with A.inputs()[0].name() and this is not just something i know, but it is also how i understand it from help so as you can see it is all about understanding python and houdini, then the help reading is easy Quote Link to comment Share on other sites More sharing options...
Symbolic Posted May 6, 2009 Author Share Posted May 6, 2009 Thanks! But you have to accept... it is a bit confusing! Quote Link to comment Share on other sites More sharing options...
JColdrick Posted May 6, 2009 Share Posted May 6, 2009 Keep in mind it's a reference, not a tutorial! Cheers, J.C. Quote Link to comment Share on other sites More sharing options...
