san Posted May 6, 2009 Share Posted May 6, 2009 how to fix this problem Warning: OpenGL shader extensions not available. This is a limitation of your video card or driver, and will prevent Houdini from using GLSL shaders. Set the HOUDINI_OGL_ENABLE_SHADERS environment variable to zero to avoid attempts to use this extension. Quote Link to comment Share on other sites More sharing options...
stevenong Posted May 6, 2009 Share Posted May 6, 2009 It's just a warning that your graphics card doesn't support the extension. You can continue to ignore the warning or set the HOUDINI_OGL_ENABLE_SHADERS environment variable to 0 and you won't get the warning again. Cheers! steven Quote Link to comment Share on other sites More sharing options...
san Posted May 6, 2009 Author Share Posted May 6, 2009 stevenong said: It's just a warning that your graphics card doesn't support the extension. You can continue to ignore the warning or set the HOUDINI_OGL_ENABLE_SHADERS environment variable to 0 and you won't get the warning again.Cheers! steven where and how to set that variable to 0 ? Quote Link to comment Share on other sites More sharing options...
stevenong Posted May 6, 2009 Share Posted May 6, 2009 Not sure which version & OS you using but in your $HOME/houdini9.5 or $HOME/houdini10.0 directory, there is a houdini.env file. You can edit that file with a text editor and do the following: # # Houdini Environment Settings # # The contents of this file are read into the environment # at startup. They will override any existing entries in # the environment. # # The syntax is one entry per line as follows: # VAR = VALUE # # Values may be quoted # VAR = "VALUE" # # Values may be empty # VAR = # # Example: # # HOUDINI_NO_SPLASH = 1 HOUDINI_OGL_ENABLE_SHADERS = 0 If you don't have the houdini.env file, you can copy & paste the above into a file named "houdini.env" and place it in your $HOME/houdini9.5 or $HOME/houdini10.0 directory. Cheers! steven Quote Link to comment Share on other sites More sharing options...
