change opacity based on world in vex
majikal
Hello!
How should i modify clay material so, that opacity on sruface would change according to world position...
z=0 opacity 0
z=>1 opacity 1
I tried this but it doesnt work:
thank you....
Edited by majikal
i would take your "z" value from your vectofloat1 VOP and wire it into the bias of a "mix VOP". Wire your Zero constant vop in to the first input, and 1 into the second input of the mix. That should work. I havent tested it yet, but you may need to wire your "z" value into a clamp before wiring it into the mix bias.
Yes this work!!!!! Thank you very much!!!!
I justy dont get why i need to use mix, why not directly position!!
