pclaes Posted May 13, 2009 Share Posted May 13, 2009 (edited) Hi, I'm trying to get some custom attribute from sops to drive the displacement inside a vop rsl displacement shop, but I am getting strange results. It seems as if the "render polygons as subdivision surface" render attribute is not being applied to interpolate between the values. I've got what I wanted working using mantra, by just checking the render polygons as subdiv. What am I missing? is there some other render attribute I need to add? attached two images, the good and the bad. Anyone have a clue - this must be a fairly common thing to do, so I'm sure it can't be that hard. Edited May 13, 2009 by pclaes Quote Link to comment Share on other sites More sharing options...
edward Posted May 14, 2009 Share Posted May 14, 2009 You need to edit the Rendering Parameters and add the Polygons as Subdivisions parameter specific to RenderMan, Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 14, 2009 Author Share Posted May 14, 2009 You need to edit the Rendering Parameters and add the Polygons as Subdivisions parameter specific to RenderMan, Thanks, but it's still not working. I did that, I added it to the object. It should be the correct one, for prman14, but still doesn't work . I attached the scene. custom_renderman_attributes_04.hipnc Quote Link to comment Share on other sites More sharing options...
brianburke Posted May 14, 2009 Share Posted May 14, 2009 Hi pcales I can't test this as I don't have a PRman lic right now, but I think its necessary to add the ri_subdivscheme attribute. Quote Link to comment Share on other sites More sharing options...
edward Posted May 14, 2009 Share Posted May 14, 2009 Thanks, but it's still not working.I did that, I added it to the object. It should be the correct one, for prman14, but still doesn't work . You attached a non-commercial file. I thought that Apprentice doesn't support rendering to prman? Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 14, 2009 Author Share Posted May 14, 2009 You attached a non-commercial file. I thought that Apprentice doesn't support rendering to prman? Thanks for the suggestions, but still no luck. In Bournemouth University we have got Educational versions that work like master versions - It allows you to render out with external renderer like prman. No watermarks or other export file restrictions. I guess it's a different type of licensing then the non-commercial version. The scene should be quite easy to rebuild in a Master, just a plane with a custom attribute painted on it, fed into the shader. I've tried adding the ri_subdivscheme attribute - makes a slight difference, when on Loop it will retopologize the mesh so it looks like triangles rather than quads, but they are still very visible. I would still like to know why it is not working - but for now I've rebuild my shader in vops and I'm using mantra. Quote Link to comment Share on other sites More sharing options...
Alanw Posted May 15, 2009 Share Posted May 15, 2009 I've never heard of that licensing before. Wow.. I also don't have access to a prman lic right now, but I can check it out this weekend. First thing I'd try is to care for your normals a little more. It's a common technique to calculate a smooth normal by obtaining the difference between the geometric normal (Ng) and the shading normal (N) and adding it to P. Try something like this. normal Ndiff = normalize(N) - normalize(Ng); P += magnitude * normalize(N); N = normalize(calculatenormal(P))+Ndiff; Quote Link to comment Share on other sites More sharing options...
