eison27 Posted May 16, 2009 Share Posted May 16, 2009 In VEX I make a layer texture in vopsurface by many different texture, and mix them together. but I don't know how to make displacement on different texture,let every one have siger bump by themself,and easy to control the bump. Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 16, 2009 Share Posted May 16, 2009 In VEX I make a layer texture in vopsurface by many different texture, and mix them together. but I don't know how to make displacement on different texture,let every one have siger bump by themself,and easy to control the bump. If you are looking for a way to do layered displacement, have a look at this thread and the vop network at the top of the page: http://forums.odforce.net/index.php?showtopic=6517&st=12 Bump is like a displacement, but you just use the normals and keep the point information the same. Quote Link to comment Share on other sites More sharing options...
eison27 Posted May 16, 2009 Author Share Posted May 16, 2009 (edited) thank's I will try Edited May 16, 2009 by eison27 Quote Link to comment Share on other sites More sharing options...
eison27 Posted May 16, 2009 Author Share Posted May 16, 2009 Thanks for your help.so you means I could make displace along normal in each texture? I study houdini not longer,could you teach me how to connect them. and if I don't make bump in vop surface but build a displacement null in shop do you have same way to make the bump? THANKS Quote Link to comment Share on other sites More sharing options...
