Adept Posted May 19, 2009 Share Posted May 19, 2009 Hi, I've made Font geo and extruded it. Then let's say I need to extrude back and front faces once more. Then I get theese edges inside. Blast SOP for deleting unnecessary edges does not seems to be helpful. edges_issue.hipFetching info... Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 19, 2009 Share Posted May 19, 2009 use poly extrude and in the option tab tick remove shared edges - that should help. kuba Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 19, 2009 Share Posted May 19, 2009 Or turn off the "hole faces" option on the font sop Quote Link to comment Share on other sites More sharing options...
Adept Posted May 19, 2009 Author Share Posted May 19, 2009 I tried all combinations with the Font's "Hole Faces", PolyExtrude's "Remove shared sides" and Extrude's "Hole polygons" and "Remove shared sides". By setting off Holes I actually get no holes, which is useless. Otherwise unwanted edges appear again. Any thoughts? Btw, sometimes it needs Reverse SOP for inside curves of every letter. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted May 19, 2009 Share Posted May 19, 2009 Just use the version without holes to make the sides, and a version with the holes for the front and back. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 20, 2009 Share Posted May 20, 2009 Indeed the problem isn' t as simple as it seems. Have a look at the file attached. Option 3 is IMO the best solution, although you have to work on bevels separately. Hope it makes sense. kuba edges_issue.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 20, 2009 Share Posted May 20, 2009 Adept said: Hi, I've made Font geo and extruded it. Then let's say I need to extrude back and front faces once more. Then I get theese edges inside.Blast SOP for deleting unnecessary edges does not seems to be helpful. Here's a different approach using a "polarity" attribute to guide the extrusions. Faces are holed separately using a Hole SOP. edges_issue2.hipFetching info... Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 20, 2009 Share Posted May 20, 2009 I like its simplicity, great example! Quote Link to comment Share on other sites More sharing options...
Adept Posted May 21, 2009 Author Share Posted May 21, 2009 Thanks to all. Mario's example is simple and beautiful Quote Link to comment Share on other sites More sharing options...
