nmn Posted May 19, 2009 Share Posted May 19, 2009 (edited) Hi everybody a simple question, if i have a grid with UVs for it, then i create a material for which the color is a ramp, what would be the method with which i can get the colors of this ramp to the color parameter in the ogl tab, so i can see it in the viewport ? and is there a way to be able to see the ramp in the UV editor so the editing of the UVs accordingly will be easier ? Thanks for your help Regards Edited May 19, 2009 by nmn Quote Link to comment Share on other sites More sharing options...
edward Posted May 20, 2009 Share Posted May 20, 2009 I think the closest to doing is this is to run a similar VOP SOP network that adds the point color (Cd) attribute. I've attached a simple example with animated uv's so that you can see it working during playback. rampColors.hip Quote Link to comment Share on other sites More sharing options...
nmn Posted May 20, 2009 Author Share Posted May 20, 2009 Thanks you very much edward for the fast reply, it's what i needed , but i thought there is some built in thingy like in maya or else i wish the representation in the UV editor could also be fully shaded not only the edges but that will suffice for the moment though Thanks again Regards Quote Link to comment Share on other sites More sharing options...
