hotkey for creating a material out of VEX
Ezz
Im going nuts here.
I cant remember the shortcut used to create a material from VEX.
I was sure it was either shift-c or shift-n.
Please help :-(
Shift+C (for "Collapse") should turn a VEX SHOP into a Material (it does for me; H10.0.282), unless you remapped the hotkeys, that is. Is that what you're after? (RMB on the worksheet should bring up the menu with all these options in case the hotkeys got remapped).
